I am having the same problem as this guy.
I remember fixing a friends PC last year with a 'fluffy' CPU cooler, but mines ok in that respect, it's a Zalman and is securely fitted, fans spinning ok.
I get no beep with mine, it just shuts off like someone's pulled the plug. Then it won't turn on again without cycling the on/off switch on the PSU (Enermax noisetaker) This takes a few 'goes' to 'latch' and start booting again. Usually happens about 3-4 minutes after turning on, then more frequently after that. Some times it comes on for a few seconds before shutting down.
After several of these 'false starts' the machine boots up fine and runs all day long with no probs. It's like an old car on a cold day, a bugger to get started, then ok after that.
I'm thinking it must be psu problem or motherboard/switching problem.
How should I best be troubleshooting these?
Possibilities could be overheating/loose component/grounding issue but none of these tally with the fact that it only happens when the PC has been off for a while. It makes no sense at all???
'May' be related but my VGA card (radeon 9800pro) died on me a few weeks back. The system was running with no apps or windows open, I was out the room a few hours, when I came back the machine was off and wouldn't reboot til I swapped out the card. Tested the 9800 in 2 other machines (pals) and again no boot so that's a goner.
