Hi All,
(PCM = phase change material)
There is a bit of a revolution going on at the moment with respect to the end of the hot water cylinder era and the start of its replacement, the 'heat battery'. Some of you will have heard about this technology already which is being spear-headed by an Edinburgh-based company called Sunamp. A better known (but slightly dodgy, historically, in my opinion) company called Fisher Heat (dodgy because they advertise resistive electric panel heaters as '100% efficient!!' - which of course they are but it misleads people into thinking they are also cost-efficient which they most certainly are *not*) is also selling Sunamp's products under their logo.
In a nutshell, and without going into the very complex technicalities (but similar principle to refrigeration/heat pump technology - and equally as magical) a heat battery will provide hot water for both washing and heating purposes (including underfloor heating) from a much more compact volume (approximately 1/3 to 1/2 the size of a comparable hot water cylinder) has much better thermal retention characteristics (saving money) and is much easier to install, maintain and arguably operate - with the exception that it is quite a lot heavier than an equivalent *empty* cylinder. It is also as good as or better in terms of compatibility with various heat sources (except back boilers and the like).
So, my question is, does anyone know of a company who is yet taking advantage of this technology to make modern night storage heaters? It seems s very obvious use for the PCM technology given that it would result in a much more compact and efficient heater with all the advantages of the original idea of night storage i.e. using night time off-peak electricity to 'charge' it and releasing that energy as heat during the day/evening when it's needed. I'd also like to imagine that they would be 'smart' and WWW-connected and therefore able to take advantage of the weather forecast to only store sufficient heat accordingly, thereby being much more efficient in terms of energy uses as well as insulation losses.
Just a thought!
MW
Just a thought!
MW
