PD work before starting PP work
29 Apr 2014
Yorkshire
Hi all, recently got pp to build in the rear garden space of my house but LA has revoked pd rights on original house and proposed house in pp decision notice. I wanted to pave the front garden and build a porch to the original house and have been advised the planning conditions only come into play once I start the new build, I was told to do the PD work first, then start the new build....is this correct?
Yes but the PD works must be complete before you start the approved works. Also check what has been revoked. Planners often remove parts A and B but not others. So you may still be able to add a porch or paving.
Good luck, don't let them charge for pp where they removed pd and would have been allowed.
rjm2k makes a helpful point: if in future you want to do any work that is PD to a person who still has the rights, but you must make a planning application, then they cannot charge you for it..
If I ever found myself in that situation, I think I'd make one planning application per week, just to clog up the system and be annoying
