Pebble dashing
10 Apr 2008
Staffordshire
I had my house pebble dashed about 10 years ago. Over the last couple of years some of the top coat has fallen off, A section next to the upstairs window and some behind the guttering, would it be possible to patch up I know they used a yellow sand for the top coat and still have some of the original pebbles. Is it possible to take some of the top coat off and re do and how much am I looking at as I can't afford to have the whole lot done again.
Yes it can be patched but you will see it.
How big are the patches? bearing in mind there may be more loose.
Agree with Alastair. You'll always see where it's been patched up, no matter how well it's been done. Even if you use the same sand and the same chips/pebbles, and do a tidy job, it'll still be noticeable. Doing the whole wall/walls is the ultimate, but depends on your budget as you said.
