- Joined
- 24 Aug 2009
- Messages
- 2,680
- Reaction score
- 282
- Country
Hi Gents - a bit of help appreciated if you would.
I have just laid my first pebble mosaic in a shower and have used too much adhesive so that in places it has squeezed up as high as the finished grout should be.
My questions are :
1) Can I leave this or will it be a problem ( see additional notes at bottom )?
2) Where there is still some height left, should I bring it up to height with adhesive or grout ?
3) What is the minimum amount of adhesive or grout that I can add and expect it not to crack ? Any preparation that will help it take ( approx 2 m2 ) ?
The mosaic is installed over rubber-sheet tanking bonded to the drain so water penetration not a problem. Walls tanked with de-coupling membrane.
Used a good-quality powder adhesive
Thank you
My questions are :
Thank you
