Hi, this is my first post, I am a complete amateur with no DIY experience, but as I have just purchased my first property I guess I need to start learning whats what and what to do!
The survey on my property was pretty good, picking up only two points that need immediate attention. I will only detail one of these here as I have questions about it.
The house is a 1930's semi with an odd DPC/render setup. The front of the property is rendered to about 1 1/2 foot from ground level with a bell finish. The side and back are rendered to the floor, this was picked up in the survey as it needs to be removed to above the DPC. I have read up a bit about this but cannot understand why this was not done at the time the DPC was applied, about 15 years ago. The DPC injection holes are visible through the render itself, so the DPC company must have just applied the DPC through the render. Is this normal?
Anyway, is sorting this out a job I can do myself? I can afford to get it done by a professional in a few months, but would quite like to have a crack at it myself. Am I right in thinking that I remove the render to somewhere above the DPC, and then tidy up the render by putting new render on down to a Bell Cast Bead? I have read various posts here that detail the mix to use and the stages to take, but if anyone can give me any info to help me avoid pitfalls (even if you just suggest getting it done professionally) that would be great.
