Pebbledashing exterior block extension walls
16 Jul 2014
Kent
The pebbledash on two of the walls of my single storey extension has fallen off to reveal the blocks it was built with. I have scraped off any remaining render.
I would appreciate guidance as to what I should do in order to recoat the walls using pebbledash, and using beading around the windows and doors. The bottom few courses are brick that has not been pebbledashed but also needs to have render re-applied as it has also fallen off.
I would basically appreciate a step by step guide, but also information regarding preparing the walls, and the mixes needed (and what products to use, including the beading and lower part of the walls).
Also, is there anything I can do to avoid it falling off again, as in some cases I can see that it had a scratch coat, although in most cases the render seems to have blown between the blocks and the basecoat.
Also, would it be possible to provide some guidance as to how to calculate quantities needed.
Your assistance would be much appreciated.
