I've just had a new ceiling pendant fitted with a dimmer switch. For some reason the light doesn't seem to work with a standard bulb (bayonet fitting) but when I put in a energy saving bulb it does light up (although flickering as its on a dimmer) so the pendant is obviously wired OK?
Any ideas as to what the problem may be? (The standard bulbs I've tried are from other working lights so are not the problem).
