Hi
I am struggling with one light. It's an old house we have just moved into using cartridge fuse box but 1 fuse for downstairs. I know it's working as other lights are. Anyway, in the front room there was no ceiling light but the wires are there.
In the ceiling there are 3 wires all with 1 green, red and black. I have found the old colours circuit and attached the pendant in the same way as other wor,king room. Admittedly I can't tell which one is the switch cable but I have tried all 3 and am sure which ( 1 blew fuse with one and it lights dimly via the hall switch with the other ) but even with elimination my problem seems to be the light switch as I can't get any light from this switch.
The problem stems from the fact that the light switch cable has different wires to the ceiling cable! Maybe it's joined above with a different cable but anyway the light switch cable has 4 wires- one green earth fine- but it also has 2 reds and 1 blue and I don't know how to put these in 1 way switch which has 1 TOP and 1 common hole OR my new switch which has L1 L2 and a common. I suspect I twist the 2 reds together in 1 hole but can anyone please help!
Many thanks
Many thanks
