Under Regulation 411.3.1.1 (Page 55 of the 17th edition of BS7671 Amendment 3), as quoted;
It is clear that that a CPC must be included in all fixed wiring except for Class 2 lamp holders, even if it is a Class 2 device at the other end.
Yet people still use the "earth" core in flex as a live conductor!
Today I found out that the HW cylinder stat at my grandparents is wired in 3 core with the "earth" core being used for HW Off. (Y Plan/3 Port valve). Same for the old CH thermostat.
What code would you give such a discovery during a EICR?
Regards: Elliott.
A circuit protective conductor shall be run to and terminated at each point in wiring and at each accessory except a lampholder having no exposed-conductive-parts and suspended from such a point.
Regards: Elliott.
