Keen not to cowboy this part of my build so looking for some advice. Seems impossible to find anything on school of youtube but maybe i'm using the wrong terms.
Room is small, so 2.1m x 4m. Will be used as an office/gaming room. Desk and a sofa will be the heavy furniture.
Floor construction (top to bottom layer):
Laminate
Underlay
Chipboard 22mm T&G
(Some sort of slip layer or vapour layer at this point?)
EPS70 75mm
EPS70 75mm
EPS70 75mm
DPM
Concrete slab
I'm constructing a floating floor, so solid concrete base (3+inches deep). Then will be using EPS70 to build up what is a 225mm gap. So it'll be 3 layers of 75mm EPS. I'm nervous about using 3 layers but assume as long as I mix the pattern up so joins don't sit on joins below I should be ok?
I seem to read a lot of bad stories about floating floors but hoping thats more down to poor construction than anything else...
On top of the EPS will be 22mm T&G chipboard, then some underlay and finally some laminate. Do I need something between the EPS and the chipboard? Guessing some sort of vapour control layer? Would the roll of tyvek housewrap i've got suffice or is it likely to break? Would I need a slip layer so the insulation doesn't squeak?
Any other advice for construction? I assume I need a 10mm gap between the wall and chipboard. Does the laminate then overlay this exactly as that also needs a 10mm gap.
Thanks all
Laminate
Underlay
Chipboard 22mm T&G
EPS70 75mm
EPS70 75mm
EPS70 75mm
DPM
Concrete slab
Thanks all
