periodic inspection?
20 Aug 2006
Leicester
hi pips!
i have a customer that i do fire alarms and e/m lighting for, she lets her propertys out.. she has asked me to do the inspections, i assume that you do a visual inspection and not a test! do i have to be PART P? can i pick the certs up from the wholeseller? also if i can do this, whats the going rate? many thanks for any advise.....
It usually involves inspection, testing and issuing a Periodic Inspection Report which should consist of a PIR, schedule of inspections and a schedule of test results.
You don't need to be a member of a competent person scheme to do PIRs but you should check your insurances.
As you are not aware of the requirements you might be better taking a back seat!
depends what they want, visual if that's what they ask for, but normally inspect & test with possible limitations agreed beforehand, do you have insurance & 2391?
Rather than auuming things, you need to find out exactly what this person wants.
Could be anything from a simple visual inspection taking half an hour to a full inspection and test of everything which could easily take a whole day or more.
cheers all for the quick repley!
i was asked to do i annual inspection not test, i rent a property and they send a guy to do a visiul inspection i have the certs for my property and they look like what she is asking for! she is only asking me to do this as the agent needs it! how much do you guys charge for a visual?
cheers
