Periodic Inspections.
31 Mar 2006
Leeds
I was carrying out a run of the mill PIR on a domestic property today ready for new tennants to move in.
I discovered the property had no earth supply.
The supply was a TN-S supply on split concentric cable. I've never seen a split con earth fail before.
Makes it worthwhile paying for that PIR :D
(I also found another 22 faults in this house)
most likely it wasn't the cable that failed but something at a joint in the distribution network.
do the DNO even test the earth when they joint a new peice of split con onto an old lead and paper cable?
I had a joint fail on a straight con PME connection. The Ze was 1135.
It turned out the link was never tightened properly. Built in 1975.....
Naturally I had my camera with me :LOL:
The link from the cutout to the MET was... erm.... different.
