I'm currently going through the process of applying for planning permission for a 2 storey extension, 5m downstairs and 3m upstairs.
Having read what is permitted development, I've found 2 points that I consider are in contention of each other, or, at least, I can't understand why one should negate the other:
My downstairs would sit largely below the fenceline for the neighbours, so in effect, it's the upstairs that would create more issues, but the distance I want falls under what would be permitted ONLY as long as I do the same downstairs. One of the reasons I want a bigger downstairs is so it doesn't look like one big ugly block stuck onto the back of the house, rather, the offset will create a more visually asthetic finish.
Could I do the downstairs to 6m for now, and do the 3m separately in that case at a future point? If not why?
In my opinion this is one point where the regs fall over; you should be able to go 6 and 3 out downstairs and up respectively, or you can't, within permitted development rules.
- In addition, outside Article 2(3) designated land* and Sites of Special Scientific Interest the limit is increased to 6m if an attached house and 8m if a detached house until 30 May 2019.
- Extensions of more than one storey must not extend beyond the rear wall of the original house* by more than three metres.
