- Joined
- 20 Feb 2021
- Messages
- 14
- Reaction score
- 0
- Country
Can anyone advise on this. The council has a document on development which states critera that would prevent permitted development. Specifically this regarding lofts.
Roof Extensions
1. Roof extensions to residential properties will only be permitted if all of the following criteria are met.
Development must:
a. Be of an appropriate size and location within the roof plane and, in the case of roof dormers, inset from
the eaves, ridge and edges of the roof (insets should normally be between 500-750mm); and
b. Be in keeping with the character of the property, and not dominant when viewed from the surrounding
area;
2. Roof extensions to the side of a property must not disrupt the character or balance of the property or
pair or group of properties of which the dwelling forms a part.
3. Roof dormers on front facing roofs will generally only be permitted if they do not materially affect the
character of the area and are not dominant or intrusive when viewed from the surrounding area.
The 500-750mm inset all around a roof loft is most concerning because that would rule out a loft extension for most houses as most are tight anyway and you would have to lose a meter minimum of headroom space. But when you look around at lofts in the area none are complying with this, so its a bit confusing. Also permitted development rules do not mention the 45 degree rule for neighbouring windows does this also need to be considered for PD?
Roof Extensions
Development must:
area;
