I have a Fluidmaster bottom entry float valve fitted to my cistern. The issue I cannot fix is that the central column is effectively two pieces (so you can adjust the height of the valve to accommodate various sizes of cisterns) and I am suspecting that a leak is escaping through the join around the two respective mid-sections even though there is a collar to supposedly compress the pieces together and presumably create a water tight fit.
I have tested it with the cistern dry and by using a pencil under the valve arm effectively isolated the valve to an off position yet water still creeps into the system for somewhere close to the collar. I have replaced the entire unit, and although initially better, within weeks it has deteriorated and an escape has reappeared.
The system is only gravity fed from the loft to an average height upper floor... but do I need to replace the washers so it can sustain a higher pressure or am I missing something more fundamental ?
