We're renting a house and after a leak from the ceiling the landlord finally agreed to replace the 20+ year old flat roof. Once the rotten wood came off and the roofers started applying the resin, the resin smell drifted into the two rooms that have plastic skylights and 2 weeks later, it is not getting better. We've aired as much as possible but it makes no difference - the stench is nauseating and it always comes back.
Apparently, it is the first time the roofers have encountered such a problem and they insist that they waited the appropriate time between resin applications. They say the roof doesn't smell when they're on it and that it has cured fully, so there should be no smell. They are also suggesting that the landlord replace the plastic skylights with glass, which should prevent the smell drifting inside. However, in addition to the smell coming through the skylights, we have a window that opens onto a portion of the flat roof and the smell is also coming in through there if it's left open. So something seems to have gone wrong.
If it were summer, we wouldn't have a problem keeping the doors/windows open all the time while hoping that it all airs out but in October, it isn't an option and we effectively can't use these two rooms with the windows closed (one of which happens to be the kitchen/dining room). Any suggestions as to what might help?
