Petrol Lawnmower - Honda Izy vs ...?
25 Jun 2011
Lincolnshire.
Hi all,
After years of electric mowers (and a brief ownership of a battery powered Rotak that was under-whelming) I am now looking to get my first petrol lawnmower.
Exciting news, I am sure you will agree.
The Honda Izy has lots of positive press (I'd probably go for HG416PK based on my garden and reviews), but recently had the Hyundai HYM430SP mentioned as a lightweight option - any others that I should consider, or would either of these do the trick?
Happy with the prices quoted for these (up-to £300) as long as I get something that does the job, doesn't complain, and is easy to store.
The Hyundai is quite a bit cheaper but this does show up in the build quality. Expect to save maybe £100 against the Honda.
The Honda is the superior machine in my opinion and after market parts are available anywhere. Both machines have steel decks so both need cleaning and painting.
Being four stroke engines, they can't be hung up at the end of the season unless the fuel and oil is drained.
The Honda dealer network is very well established, unlike the Hyundai.
John :)
I would go for the Honda, or at least something with a Honda engine
My dad bought the earlier version of that mower brand new at the millennium, it's still going great at 18/19yrs old although I had to fit a new deck in 2015 (he doesn't do much cleaning/painting on it)
I would get yourself down to your local tip - you will be amazed how many really good petrol mowers go for under £25. most only need a change of oil and a spark plug. The vast majority have the same power unit.
Thanks all - as I am new to this, when it comes to cleaning/painting the steel deck is there a guide? Is it a case of cleaning off after each use and then painting at the end of the season? Or something more?
Will give my local tip a try too
Had my brigs n Stratton 4.5hp mower for 20 years.. changed the oil twice and the spark plugs once. Never cleaned it o_O:mrgreen:
At the end of the season, drain off the oil and fuel and tip the machine right over. Take the blade off (14mm bolts, ) sharpen it and then scrape the deck underside, treating any rust before giving it a heavy coat of Hammerite.
New decks are around £120, you'll get 10 years without any treatment.
John :)
I clean out under my Honda's deck after every time I use it. Three years and no rust so far.
I would definitely go for the Honda
