Peugeot 106 door lock fault, have to exit thru the window!
18 Nov 2006
Hi all,
Anyone have experience of the drivers door becoming jammed on a peugeot 106? At present its either a dukes of hazzard style window exit or clamber across passenger seat..passenger... etc :oops:
the key turns in the barrel, door handles moves as normal, both inside and out but no opening is taking place :(
the central locking seems to be well because if i hold the exterior handle out and push/pull the the little interior lock pull all the central locking units on the vehicle lock and unlock, including the unit in the faulty door.
Am going to attack it with torx bits from work on monday cos at present i can't get the door card off or the drivers seat out to give me space to work.
Any suggestions would be most welcome, i can rebuild engines but can't open a door...............infuriating!!! :rolleyes:
