L lesdonna Joined 15 Dec 2011 Messages 4 Reaction score 0 Location Wiltshire Country 15 Dec 2011 #1 the indecitors where working fine this morning now they dont work at all including hazards you can hear the relay clicking but no lights on the car or dash the car locks on the remote but does not flash can any one help
G gman76 Joined 19 Jan 2006 Messages 558 Reaction score 32 Location Wiltshire Country 15 Dec 2011 #2 Hi there, Are you sure it's the relay you can hear? My 206 has a generated "tick tock" sound that emanates from under the steering column. Have you checked the fuse?
L lesdonna Joined 15 Dec 2011 Messages 4 Reaction score 0 Location Wiltshire Country 16 Dec 2011 #3 gman76 said: Hi there, Are you sure it's the relay you can hear? My 206 has a generated "tick tock" sound that emanates from under the steering column. Have you checked the fuse? Click to expand... yes i have check the fuse when it take the indicator fuse out the tick tock stops it only makes that noise when you put the stalk up or down
B Burnerman Joined 7 Feb 2008 Messages 25,643 Reaction score 5,548 Location Northumberland Country 16 Dec 2011 #4 Did this problem first start after you had used the hazard flasher switch? Its a notorious part for failing on Peugeot / Citroen. John
L lesdonna Joined 15 Dec 2011 Messages 4 Reaction score 0 Location Wiltshire Country 16 Dec 2011 #5 Burnerman said: Did this problem first start after you had used the hazard flasher switch? Its a notorious part for failing on Peugeot / Citroen. John Click to expand... no only when i used the remote to lock the car when i got in it and drove off went to turn right and thats when i had no indecitors or hazards
