This car has developed a very annoying problem!
If the engine stalls when it is hot during a journey sometimes it fails to start.
It seems the EMS is preventing the starting motor operating because it thinks there is a serious problem.
It will usually restart after 5-15 minutes.
Initially I thought it was low oil level but it never indicated that and it still happens with a good oil level. Then it showed low battery plip. I could not see why that should have prevented it from starting and it locked/unlocked from 100m away no problem. But I replaced the plip battery. But yesterday it again failed to start again.
Now it has ALWAYS eventually restarted ! It does not show any indication of a fault on the panel just fails to run the starter. It never fails to run once started. The fault only affects running the starter motor and sometimes indicates a "STOP" but not always.
I do wonder about an overheat condition but it shows not much over 90C on the gauge and the cooling fans do switch in as required.
The only causes that I am aware of that block the starter motor are:-
Door open.
Low oil level.
Now what other causes can block the starter motor?
Door open.
Low oil level.
