Peugeot 406 petrol.
26 Jun 2004
London
Exhaust hit road hump yesterday!
Centre support bush came out and two rear ones broke!
I tied it up to complete the journey, not as high as it should be and manifold joint was blowing.
Today I reconnected the centre support and Q-F gave me one which I fitted at the back. Its not blowing much now but is still leaking and letting CO into the car.
What is likely to have happened to the manifold joint ? Its behind a heat cover so I cannot look at it.
Tony
Possibly snapped bolts/studs, in the manifold, a cracked manifold,(cast,crack easy),? stretched bolts in adjoining sections could also add up
As far as I can tell the manifold is solid but the joint, however that works, was clearly loose when I felt it before I finally placed the exhaust in the mountings.
Tony
Put your car up on ramps, start the engine and have your mate cover the end of the exhaust with a rag. You look along the exhaust for the leak(s).
As I tried to explain, the leakage is at the connection onto the manifold but this is behind heatshield and has little space between engine and bulkhead.
I dont know what kind of joint is used on this car ( yet ).
Tony
if its had a good smack whatever flexi coupling is used on the front joint may have snapped bolts or the sealing ring may have come out
