Hi
Any pros/cons of using PEX, PB or copper.
I want to try and run the pipes through an existing stud wall, so on the face of it plastic pipes would be easier to install and need less joints.
Do verticall plastic pipes need any special support when running vertically though stud walls?
I saw on an US website PEX is better than PB, as it is less likely to fail and more resistant to chemicals in the water like chlorine, but not sure if they use the same pipe over there.
Any advice appreciated.
Cheers
MisterG
Cheers
MisterG
