Philmac 25 x 15mm Metric Imp Copper Connection Kit
16 Jul 2009
Hull
Any one know which way around the 3 pieces to this kit go. I know I need to remove the grab ring from the 25mm mdpe philmac fitting but unsure which way around the reducing kit goes.
Philmac 25 x 15mm Metric Imp Copper Connection Kit 86032
Click to enlarge
Both bits are upside down in those photos.
The silver ring makes contact with the wider end of the rubber bung.
Thanks so what goes in the fitting first the rubber or then plastic bung? Thanks there no instructions with it
Narrower end of the rubber adapter goes into the fitting, then the 15mm copper pushes into the wider end.
The silver ring and plastic piece together secure it in place.
