Hello all, perhaps someone can give me an idea if I have missed anything.
Went away for the weekend all was working fine......
Come back, and internet is not working, did the normal rebooting router etc, still no effect, removed all devices plugged into the phone line. However Phone still works in the "extension sockets" . just not the ADSL BT line check shows fault within the property.
Removed all extensions (using the faceplate) plugged it in directly to master socket and it all now works correctly.
So it must be the internal wiring, so I removed the face plates along the wiring, and all look ok, I then split the wiring from the first extension socket, (so connecting master to second) this worked (from the master socket location). Joined the first, second, then third, together, and it stopped working, (the adsl). --- all extra devices have been removed from extension sockets
Got out the multi meter, and connected the wires at the end of the extensions - WB - BW / WO - OW / WG - GW (3rd extension its alot easier to get to), all of the connections are connected (ie completed circuit, and have the same resistance along its length give or take.)
Any ideas why? Next step for me is to swap out router, but I have never seen a router do this before.....
BT SOCKET --> Bedroom --> Kitchen --> 2nd Bedroom --> Living Room
---------------------- 1st --------- 2nd ------------ 3rd
Anything else to look for or guidance would be greatly appreciated.
Jason
Jason
