Photocell supplied with single insulated cables?
22 Jan 2012
Jersey
I've never used a pre-wired photocell. Is the bottom threaded like a normal one for the cable gland? If so, can you not just bring your cable in as normal, trim the existing cabling and join to your cable?
That is a cheap and nasty looking photocell though. Cities stock a nice looking one with a totally clear (rather than opaque-clear) dome.
Thanks for the advice. I will sling the cheap photocell, and have ordered a Steinel Nightmatic 2000 - all cabling should be concealed and it has infinite lux adjustment.
Wish I had asked first!
You've been here for 4 years - sure you've never seen people advising against buying cheap Chinese tat?
is it not one of them NEMO sockets or whatever there called
th
