I bought a piano for my daughter and only way that can get into first floor is via balcony door.
Juliet balcony is fitted on bolts and I simply assumed (DIY novice) it was easy to remove with the help of few strong people, but looks like it has a lot of weight. I also approached a local builder but it all seems to be too complicated involving boom lift, damaging bricks (if resin filled fittings) etc.
Here is the video taken for piano delivery company
https://www.youtube.com/watch?v=RATdyDsolRw
Would it be possible to cut the juliet balcony partially to expose the door, so that Piano can go in vertical position? There is only one door and rest are fixed glass fittings. If this is doable I don't have to worry about damaging bricks, huge expense of removing and re-fitting the balcony. Close up picture of balcony linked below.
http://i36.photobucket.com/albums/e12/suniil/DSC00423.jpg
I've free hold ownership of the property, would council pull me into troubles by doing it?
Please share your expert thoughts.
Thank you
Sunil
Thank you
Sunil
