I'm about to move again. This time I need to take my pianola with me. Since I have had to disassemble it (to get it through the doors), I have decided to take this opportunity to completely renovate it. It is still quite playable (or was until I took it apart) but could do with some attention to the action, rubber hoses, and I would really like to bring the case back up to scratch.
Now my main concern is a crack, that is about 12 inches long and goes all the way through the thickness of the lid. As you may see from the pictures, this crack is not obvious unless you apply some pressure to distort it. I'm not sure what wood the lid is made from but it is covered in Burr Walnut veneer. (I know it was made in 1904 by Weber if that helps)
Any ideas what I could do to stabilise this area to prevent the crack getting any larger? I was thinking something along the lines of PVA but the two sides of the crack naturally hold themselves very tightly together.
I'm also concerned that if this repair is bodged it could seriously devalue the instrument.
Finally, I would also like to re-finish the case. It probably has over a hundred years of pledge on it, so I'm sure it would look better if I could remove this junk and bring back it's former luster. Any tips appreciated.
