Pick foam / shadow foam for toolboxes
2 Dec 2015
Morning,
I’m after some of the above but it’s pricey. The systainer specific stuff is £10 per box and I have 20+ systainers.
Is there a cheaper alternative or supplier anyone knows of?
Ta.
Find a foam supplier who sells sheets of "diced foam". It's used a lot in the packaging industry to protect tools and precision instruments. The material itself should ideally be "ballistic foam"
Not much found on Ebay that's not manufacturer specific and hence expensive.
Perhaps the non diced stuff can be used and cutout the shapes yourself?
google Kaizen foam
ebay seller here
For some things I avoid eBay. Instead I went to a foam seller's website. e.g. eFoam (took me a while to remember the name) who sell pre-cubed inserts and also sell die cut foam, so they might already have a die cutter for your Systainers. They also do the "rippled" stuff for lid inserts, etc. Personally I'm not that bothered about specifically sized sheets as the stuff cuts reasonably well with a sharp jigsaw wavy knife blade, e.g. Bosch T103AWP:
Thanks for the suggestions, plenty of options. I like the cubed foam I think, and possibly a firmer foam but not that fussed about he firmness. It will get used for power tools.
