They're Makpac cases. Licenced from Tanos I believe
Actually, they aren't licensed. Makita did supply some of their tools in real Systainer Classics a few years back (mainly in Germany) while in the UK they offered a Systainer look-alike for a while with some kit which unfortunately wasn't compatible with the Tanos/Festool products. The Makpacs are something new and are compatible. Incidentally, they aren't the only manufacturer who has designed their own compatible cases - Metabo has also done the same with their current
Metaloc cases (having ppreviously bought from Tanos) and there are other third party compatibles coming onto the market now, such as
Sealey. These newcomers are fully compatible with the Systainer Classic, but have limited compatibility with the Systainer T-Loc (just like Tanos's own products in fact). Makes me think that the original Tanos patents have run-out
The reason I'm trying to be tight, is firstly I didn't pay what you're suggesting
OK, so £20 to £30 a pop for Makpacs. Still doesn't change the cost of the tool you want to carry inside.
The reason I feel the Kaizen stuff is expensive is because it's no different to that normal packing polyethylene you get in a lot of modern day technology parcels. Unfortunately it's not really in a shape or size that can be used for what I want.
And there you have it in a nutshell. The Kaizen foam is diced rather than a single block and it can be had in nicely shaped pieces which fit a Systainer without the need to trim it at all. You are paying for convenience.
If you want pick and pluck foam sheets you can get it from firms like
eFoam but it tends to come in largish quantities because it is a bulky, relatively low cost product and they are hardly going to make money on a single 1/6 sheet size piece (that and postage costs would be prohibitive). Or you could always go round local packaging suppliers to see if you can get hold of "ballistic foam" in small quantities but having done this myself I in the past I wouldn't hold out much hope of success.
It's simply a matter of simplicity moving from job to job.
Yes, I know. I started to move to Systainers/Makpacs/Metalocs about 7 years ago. I'm still only about 70% of the way there (and some tools will never fit in a Systainer), but it is a lot easier to clip 2 or 3 tool boxes together (times two - one stack for each hand) to cart to and from the van. It makes setting up and packing up a lot faster and keeps the back of my van tidier, too
BTW, have you considered the Tanos/Festool Systainer tool totes, or the recently introduced Makita Makpac version, for hand tool storage and transport? They are really handy
