Pilot light keeps blowing out
14 May 2012
I have a mature LPG Baxi boiler, in good order normally and serviced annually.
I am having problems with the pilot light being blown out, I think it may be due to wind coming down the chimney is this possible and if so what should I do about it?
Is this something that has suddenly occured?
When was it last serviced?
Tony
Boiler is a Baxi Bermuda.
Serviced last November. At which time the gas mans used a reader and said the fire and boiler reading are better than todays models.
pilot light was blowing out in very strong winds in the Spring, but always re ignited easily.
I had the chimney pot and liner checked today, apparently all is sound out on top.
If you are wondering I have called the ' gas man' several times, all I get is voice mail, I have left messages.
Never seen a Bermuda fitted to a chimney/liner that suffers from wind blowing out the pilot.
There is something else causing pilot failure and it is not for DIY.
Get another LPG accredited engineer to service and repair it.
Are you in a typical two story house and not in a particularly exposed location?
If so then as suggested it sounbds like a problem with the boiler itself.
The engineer could be on holiday? Does it ring first before or go direct to voicemail?
Tony
Boiler needs serviced dirt has got into pilot assembly
Its also possible that a part is failing!
I saw one yesterday which had gone open circuit.
Tony
Thankyou all for your replies,
the phone rings before it goes to voice mail, does this mean something?
When I do get a 'gas man' to come I will let you know the results.
If it rings with normal UK ring tone it implies he is in the UK.
It may well be that he is ignoring you!!!
That can often be because we see BBUs a time consuming to work on for even minor faults because of the need to remove the fire front etc.
Tony
Thank you Tony, the last twice the 'gas man' came I had already taken the fire front off.
Answer to a previous enquiry I live in a cottage built in 1892 which is situated in the middle of a 66 acre field, no trees nor buildings for shelter and the winds do blowand howl, it's great but better if the heating is working.
Which area of the country do you live in? Is it two story?
There is a simple electronics test which an engineer should make to test the component which I suspect is at fault.
There is a less scientific test which you could do yourself. Its not the correct voltage measurement but it does give a rough indication. Lie down in front of the boiler and get someone else to turn off the gas and measure the number of seconds before you hear a click from the gas valve as the no flame protection operates.
Tony
Gas man has been :D !
Fitted new thermocouple, but could not light pilot light at all, found jet to be blocked, jet should have apparently dropped out of component but is firmly fixed, chap managed to unblock jet with needle.
All now working although pilot sounds like a jet plane, this is an exaggeration but it is loud.
Oh and as regards the gas man not answering my messages, he down loaded an update which stopped the phone working completely!
chap managed to unblock jet with needle. :eek: :eek:
If it was cleaned with a needle you need to get him back to fit a new pilot jet
