Pinning breathable membrane on plywood
30 Mar 2015
What type of screws or nails should I use for this? I’ve staplers being used but I don’t own one of these.
Thanks in advance.
I use a basic staple gun like you’d buy anywhere for stuff like that. Or you can get bigger ones from screwfix etc. If the gun isn’t quite up to the job a single tap of each staple with hammer sorts it
Ordinary staples will rust away in damp conditions.
I think panel pins might pull through.
They're only to hold the membrane in place during construction, there'll be battens going on presumably.
