Pins on plug get hot when heater is on for an hour.
29 Dec 2007
Invernesshire
My son moved into a flat recently and does not know the wiring history of the flat. Het said when he plugged in a 2.5 Kw heater, found the pins of the plug were very hot when he unplugged it an hour later. What action would you recomend. He does not want to get an electrican in, as he has just finished paying for the plumbing work done and is saving for the other work needed.
Some sockets are just cheap and can cause a high 'ish' resistance between plug and socket, which can then generate some heat.
Or, more commonly, loose terminals in the PLUG or the SOCKET.
Check for loose terminals, and if this is no good, replace the socket.
Also check the fuse holder in the plug is good and solid, and the fuse is held tightly - Again, old or cheap plugs can have an effect.
How hot is hot?
Pointless saving for other work if the house burns due to a defective socket overheating.
If the socket has become hot ( more than just warm ) for whatever reason the contacts (and possibly the switch) are likely to have become damaged and more heating will occur due to poor contact between socket and plug.
Agree with what other sparks have said.
Why do people always put Plumbing before electrical :?:
You'd swear electrics and faulty electrics are not dangerous.
And still working perfectly.
This shows that there is no need to worry about overheating plugs - right?
Sometimes in a 13A plug, the cable clamp can be too tight and break through the cores. If some get severed this can cause high resistance and therefore heat.
That charring with its carbon content could create an earth leakage path.
Assuming there is an effective earth to the socket......
How 'hot' is 'hot'... That is the question.
My hot water taps deliver at 58 - 60°C - try some skin under that !!
:cool:
I would check for loose connections as others have said. If that doesn't solve it then I would replace both the plug and socket involved with good quality ones.
