Hi
I've got a preety annoying problem on my hands. Basically, when I switch on my hot water, its begins to heat up with a few minor noises coming from the boiler itself and then after approx 8-9 mins, one of the pipes starts to bang and shake violently! At this stage I have to switch it off as the noise is so loud, it seems like something's going to explode!
Also, I can hear water swirling violently inside the water tank which is placed just above the boiler. Sometimes, there is expulsion of steam/water in the central heating header tank in the loft where the vent pipe enters and therefore excess water being expelled from the overflow pipe.
Also, my central heating and hot water run through a diverter valve. I have the temperature control on the hot water tank set to 50c, is this ok? Additionally, the head on the breather pipe/valve which protrudes from the hot water tank is completely closed. Is this ok or should it be a little loose so that air can expell?
Does anyone know what this problem could be?
Any urgent help would be highly appeciated.
Thank you.
Thank you.
