I need to find a suitable cable/pipe detector, but the problem is it is to used on walls which are made of reinforced concrete.
The reinforcement is usually at half wall depth, but the cables and pipes are just below the surface in plastic conduits.
Since the pipes are steel I assume there would be confusing readings, or are some detectors capable of variable depth detection?
Would the cable finding part still work in these kind of walls?
If these things are possible, any recommendations?
