I will be drilling holes in my joists to pass through 22mm copper. I've read up on regs and am familiar with this. Every so often I will be using push fit elbows and dropping down to rads with 10mm plastic.
The regs require the holes to be 1 metre away from the wall and the tee should be located away from the joists so probably in the centre of two joists. This will mean that the 10mm plastic will be floating in between the joists before it meets the wall chase where I plan to clip it. Is that okay or should I be putting un battens and clips within the joists?
Thanks in advance.
Thanks in advance.
