Pipe fitting leak.
5 Nov 2015
Gloucester
Hiya,
I used the straight coupler to joint an old pipe which is slightly small than the new one (22mm) ‍♂️. It has a slight leak on it. Is there any way that I could seal it without drain the system again and soldering it?
You should have used an imperial to metric conversion coupler 3/4 in to 22 mm. End feed or Yorkshire as you prefer.
Yes, i just notice that :(
Now i have to drain the central heating system again to fix the issue. However, is there anything out there that i could just glue or paste it on to stop the leak?
No. You have to drain out and do it properly !
C'mon... You soldered it the first time... You really think there's a shortcut... Nah! You know you don't! ;)
