Armaflex is the easiest to apply.
So will be the cheapest option and also the best imo.
In refrigeration low temp systems phenolic foam is not an option as it won't hug the pipe.
Therefore ice will form and the insulation will burst off. Fridge pipe laggers are the best in the business.
