I have a 25mm flexible VESDA pipe:
http://www.pipestock.com/vesda-pipework/vesda-red-25mm/red-flexible-connector
As you can see, it's a wire reinforced, transparent pipe with red ABS ends. One of the ABS ends has separated from the transparent pipe. Looking at the end, it was previous glued on. I'm not entirely sure what the transparent section is made of and so not entirely sure what to glue it back on with?
Suggestions would be gratefully received. Thanks.
