Hi all,
I have moved my boiler from kitchen to garage and it is now higher up than it used to be.
Its a vented system with header tank in loft.
I cut a void in the kitchen ceiling where the old flow and return pipes came down and ran them out into the garage through the wall @ this point(when ceiling is made good the pipes will be hidden between ceiling and floor.)
However the pipes now have to travel about 15" up to the boiler flow and returns...is this OK??
(read somewhere about pipes must travel upwards from a vented system...but im not sure if that was only WRT the actual vent pipe)
Cheers,
Marty.
Cheers,
Marty.
