I need to put a 22mm x 15mm reducer in.
I used plastic push fitting into copper pipe first- this held but had a small drip leak.
So I tried a copper compression reducer, same issue, small dripping leak.
Now I have put a Yorkshire fitting on, added extra solder - still can't get a fixing!! The solder just drips out the bottom and doesn't look like its going to be water tight.
I've measured the pipe and it looks like its more like 20.5mm rather than 22mm so I think this may be where my issue lies.
Any ideas???
I need help! Now got no water
Any ideas???
