Pipe size from pump!
25 Mar 2006
Essex
Hope someone can help in some plumbing questions regarding a granny annexe.
If I were to use a hot/cold pump to supply firstly on the hot side, shower, basin, sink, possible washing machine and the same on the cold side, would any of the pipework have to run in 22mm or would 15mm be fine?
Also, the hot supply to the pump from the cylinder should be what size, and the size of the cold water tank to the pump?
One last thing, the size of the supply from the cold water tank to feed the hot water cylinder?
Any recommended pump would be greatly appreciated, also hot water cylinder, I believe size 1050mm x 400mm and able to take 2 immersion heaters!
Many thanks
Many many thanks
