Pipe size vs pressure loss
13 Oct 2003
Does anyone have the pressure loss vs flow rate table for 10mm pipe that they can pass on? Information I have only goes down to 15mm.
Thanks :D
my table goes down to 12mm. the flow rate for 15mm is double that of 12mm. i wonder if the flow rate for 10mm is a little over half that of 12mm. so possibly if you half the flow rate for 15mm and then half again you might get a rough idea for 10mm
