I need some advice as I think I have hired a cowboy plumber who came with good recommendations...
Have a 3 story house (via loft conversion).
2 Radiators in Loft (1 Single Large, 1 Bathroom)
4 Radiators on the first floor (1 Large, 1 Medium, 1 Small, 1 Bathroom - All single)
5 Radiators on the ground floor. (2 large double, 2 medium, 1 small).
The job was to repipe all houses inc bathroom, new radiators and install a new boiler.
The boiler installed is a 40kw combi boiler.
A plumber has used 15mm plastic pipe throughout the property with an exception of 2m 15mm copper pipe coming out of the boiler.
Also, the pipe from the boiler on the ground floor to 2 bathrooms on the first floor and the loft is 15mm. Is this sufficient or should it be 22mm? Will 22mm cause flow issues?
My understanding was that we need to use a 22mm pipe from the boiler for hot water radiator feed and only use 15mm when splitting at each floor?
What is the recommended approach for a property of my size?
Thanks for all the help. This is stressing me out...
