we have no heating yet but want to put pipes into bedroom to accept stelrad radiator - called them to ask what distance pipes coming through floorboards had to be to then attach a 900mm rad. They said ' same as rad 900mm its flush fitting' - this seems odd to me as I thought pipe came up to TRV and then the TVR went horizontally to join the rad. If rad is 900mm and pipe centre comes up at 900mm wheres the room for the valve?
Basically I want to know where to position pipes and what spacing is required between them for a 900mm and a 600mm rad. Also how much space is required between pipe and wall (ie: end of TRV) - do I have space for a 600mm rad with a total allowance of 800mm between wall and door arcitrave. Can someone spoon feed me here!
Is better to use 15mm if I can rather than 10mm?
Many thanks
Many thanks
