pipe work behind plaster bord
14 Sep 2008
West Midlands
Hi
Just a quick question , im in the porcess of re piping the supply in our utilty room . i would like to know is , is there anything i need to do to the plastic 15mm pipe that im going to run between the plaster bord and the brick work.
do i need to run it in trunking or can i just clip it to the brick wall then plaster over it ?
thanks
Test it first,can also tape with ali foil tape so it can be located ,for drilling holes ,etc. IF it's not hard to install in an accessible duct then that may make it easier for the eventuality of any problems at a later date. Otherwise you can plaster over as described.
