Pipes Banging and Thumping when there's no Activity
21 Apr 2012
Buckinghamshire
Hi, I've searched previous posts about noisy pipes and usually it's when there's activity, such as heating or toilet or taps etc. The problem I have is extremely loud thumping. I think there is some steel pipework under the floorboards / in the loft etc. Council house, 1950s. It is more or less constant - every five or ten minutes, really loud banging and thumping. Like someone is banging a cast-iron saucepan against the walls. Driving me mad. It's not triggered by any activity at all, happens when the gas central heating has been off for days and also is not triggered by use of taps etc. It is constantly happening regardless of any activity. The only thing I've determined that will stop it, is if I turn the water off at the main stopcock. Then it doesn't happen. Do you have any advice / ideas etc please as it's driving me crazy! Only lived in the house for a month or so. Thank you.
The stop tap, stopping the noise, suggests it is external to your property - a neighbour's system generating the noise. Find out which neighbour is absent, when the noise is not evident, then you will know which. Knowing which, you can then go and have a chat with them.
Get the pressure checked and flow rate.
Might need to install a pressure reducing valve and a shock arrestor.
