- Joined
- 5 Feb 2006
- Messages
- 156
- Reaction score
- 0
- Country
Hi
I wonder if anyone can help with this? In a bedroom in our house a persistent clicking noise can heard. It lasts for at least 30-60 minutes after turning off the heating system.
So I lifted a floorboard and was almost lucky not to have cut a pipe with my circular saw due to the pipe the pressed hard up against the floorboard. Unfortunately, the floorboard runs perpendicular to the pipe so can't easily track it as it makes its way to the other side of the radiator. Of course this means the joists are parallel to the pipe.
Anyway, presumably its not great practice to run pipes hard up against the floorboard? And presumably that is what is making the clicking noise?
I did try a quick fix of putting a sliver of rockwool between it and the board but it didn't help. Is the only way to sort this out to remove dozens of other floorboards, drain the system and somehow redo the pipework in that room to have it lowered? How should a pipe run under the floor in such circumstances? Clipped to a single joist halfway between ceiling below and floorboard maybe?
Thanks in advance for any replies.
