We are in the process of digging foundations for a small side extension (approx 2m x 4m) to create extra space in the existing downstairs bathroom and a utility room. It may be small but the plan is to extend upwards in a few years time.
We have opened the trench and located the foul water drain. Spoke to BC officer and he has asked us to step down around the drain so get the concrete underneath. Ok - no probs we thought, however...
We have now come across a smaller diameter pottery type pipe set a couple of inches lower than the foul drain at a steeper angle to the horizontal. It was suggested this could be a surface water drain however there is no down pipe anywhere upstream on this side of the house - any suggestions?
Second, we have also found the mains water supply pipe into the house. It is simply a 15mm copper pipe running alongside the foul pipe. There is no wrapping around it. Personally I would like to move it as the stop cock inside the house is directly in the way of the opening for the new bathroom extension - can I do this? Or would you take advice from BC? I want to blank it off until BC have passed foundations and trench has been filled and then I can re-route it into house - I know it means no water for a couple of days.
Suggestions welcome, thanks.
