Hello
We had a new bathroom fitted before Christmas including a new towel warmer to replace a radiator. When it was done the radiators in the house weren't warming up and the plumber put this down to the ball cock in the tank so he changed it. Before that though he discovered there was an air lock in the system which he drained but that didn't help. The old ball cock worked fine before the new suite was installed but apparently not afterwards? However since then the pipes under the sink or behind the washing machine (next to the sink and this is where it sounds like it's coming from) have been making a quick double knocking noise when the boiler is off or on. Also I have noticed it knocking when the kitchen tap is turned off. It seems to happen less when the heating and hot water is on. I'm wondering whether or not the knocking pipes are down the new ball cock if that's possible. The boiler is a condenser.
Any advice or ideas would be welcome.
Phil
Phil
